Installed the 2mm aluminum on the lathe together with a wooden disc. I tried to bend it with a bearing around the edge while the lathe was turning. I figured out, that a lot of force is required to do that job. This piece has to be perfectly balanced and cocentric in order to run smooth with an engine RPM of about 2300.
